fearless_fool
Jan 22, 2014Aspirant
What do I need to know before swapping in a new drive?
As reported in http://www.readynas.com/forum/viewtopic.php?f=24&t=74918, one of my SAMSUNG HD103UJ drives in my ReadyNAS NV is on the decline: the system gets stuck on FSCK at 92%, Raw Read Error Rate...
fearless_fool
Jan 23, 2014Aspirant
Thank you everybody for informative and detailed responses.
The new disk has been inserted and is currently re-syncing -- RAIDar reports 66 hours to complete (and climbing?!?).
The log looks reasonable, but I have a question about it:
Should I start a RAID volume resync now (as the log file requests)? Or is it actually underway? Or do I do a RAID volume resync after the device resync finishes (now reported as 88 hours from now?!!!??)? (Will it converge?)
Severity Date Message
Thu Jan 23 14:35:04 PST 2014 A SATA reset has been performed on one or more of your disks that may have affected the RAID parity integrity. It is recommended that you perform a RAID volume resync from the RAID Settings tab ( accessible in the Volumes page => Volume tab in FrontView ). The resync process will run in the background, and you can continue to use the ReadyNAS in the meantime.
Thu Jan 23 14:33:25 PST 2014 RAID sync started on volume C.
Thu Jan 23 14:33:24 PST 2014 Disk initialization successfully finished.
Thu Jan 23 14:33:20 PST 2014 Disk add event occurred on SATA channel 3.
