danizmax
Aug 05, 2013Aspirant
What does SMART ATA error mean exactly?
Hi, so NAS started sending me mails about one of my HDs failing, at every start. It's a Seagate Barracuda 7200.14 (I got two identical in mirror mode) which is also in compatibility list (http://k...
Aug 26, 2013Guru - Experienced User
Grab the seatools error code, as it will make your RMA simpler.
Even if the format doesn't completely work, it is likely to destroy enough of the partition structure that getting even part of your data would require a forensic recovery. Seagate will destroy the disk properly once they receive it anyway, they certainly cannot recertify it.
