Damien89
Dec 03, 2014Aspirant
What does this mean in raidar?
Today the electricity in our neiborhood turned off all of a sudden, now when i turned everything on i have a yellow light in raidar, what does it mean? (readynas duo v2)
vandermerwe
Dec 03, 2014Master
Can you access the data?
Do you have a backup? If you don't, make one now.
This could mean a disk failure in which case you are in a precarious situation if you don't have a backup.
There are various steps to take to try to diagnose this, but you need to backup first. Post back once you have done a backup.
While you are backing up, order yourself an uninterruptible power supply with a USB connection, post a question if you need guidance on model.
- Sep 11, 2022Retired_Member
