Damien89
Dec 03, 2014Aspirant
What does this mean in raidar?
Today the electricity in our neiborhood turned off all of a sudden, now when i turned everything on i have a yellow light in raidar, what does it mean? (readynas duo v2)
Damien89
vandermerwe wrote: I mean the chassis. If it is still under warranty it's worth contacting support and adding the case number to the thread title.
Look at page 72 of the manual:
http://www.downloads.netgear.com/files/ ... 20NV+%20V2)/RAIDiator%205.3%20SW%20Manual_5Sep12.pdf
I'll have to check if its still under warranty because i dont know if its a 2 or 3 year warranty.
The link you supplied does not work and what is smart data? How do i check it?
Could it be that the external hard drive connected to the nas which is failing?
- Sep 11, 2022Retired_Member
