Damien89
Dec 03, 2014Aspirant
What does this mean in raidar?
Today the electricity in our neiborhood turned off all of a sudden, now when i turned everything on i have a yellow light in raidar, what does it mean? (readynas duo v2)
vandermerwe
Dec 03, 2014Master
I've edited my post so the link should work now.
If you look on page 72 it'll tell you where to look for the smart data.
Perhaps google smart data and learn a bit about it.
Raidar is indicating a problem with your on board volume. It means what it says, that your volume is not redundant. Either a disk has failed or one of the disks has fallen out of the array. What does your volume page say in dashboard. Read the manual if you don't know where to find this
The external drive can be seen from the dashboard and again you should be able to see its smart data. If you want to see if it's contributing, just unmount it using the dashboard and reboot the nas.
