Damien89
Dec 03, 2014Aspirant
What does this mean in raidar?
Today the electricity in our neiborhood turned off all of a sudden, now when i turned everything on i have a yellow light in raidar, what does it mean? (readynas duo v2)
vandermerwe
Dec 03, 2014Master
Yes test the disks.
While you are testing the disks you could try to factory default the nas with a spare disk.
This will of course wipe the disk. If the unit sets up normally it basically excludes a chassis problem. If that is the case you could factory default with the 2 original disks if they are ok and restore your data from your backup.
The warranty is 3 years so you should contact support if in warranty.
