Damien89
Dec 03, 2014Aspirant
What does this mean in raidar?
Today the electricity in our neiborhood turned off all of a sudden, now when i turned everything on i have a yellow light in raidar, what does it mean? (readynas duo v2)
Dec 08, 2014Guru - Experienced User
Generally your retailer will replace a failed drive with a new one if you contact them within a couple weeks of purchase.
After that you end up RMAing the drive to the manufacture (WDC in this case), and you get a re-certified replacement.
- Sep 11, 2022Retired_Member
