Kumaran
Sep 14, 2016Follower
What if NAS server fails? Can I read disks outside NAS server?
Dear forum-mates, I have zeroed in to buy RN204 based on my usage. But one thing not clear to me from my internet search is that Q1) What if the NAS server fails? Is there any way to read dis...
ideadude
Sep 15, 2016Aspirant
Better yet, you should be backing up your NAS (via usb) to a portable HD which can be removed off site. The backup will be in windows format so you can read it with your PC or Mac.
The NAS will come with a backup application to do this and it works really well for doing these back ups to a portable USB HD
On our NAS we use it to store data, movies and tunes in different directories.
We also have a set of directories to do unencrypted bare metal back ups of the PC's. To backup my PC's I prefer QuicklyTec Quick Shadow which will back up to the NAS
You NAS is not really a backup, but a place to store data that has redundant HD's. You should back up you NAS in case there is a fire. flood, electrical surge .....
Cheers
