XrayDoc88
Mar 24, 2020Apprentice
What Is The Current Maxiumum Storage Capacity Of ReadyNAS 628X?
Netgear hasn't updated printed specifications for ReadyNAS units since 10 TB hard drives were the largest available. If you look at the current description of the 628X they say the maximum storage i...
XrayDoc88
I currently have 6 drives in X RAID. I don't really need to add any more drives currently for extra storage. When that becomes necessary however, drive 7 will turn on RAID 6? Will I lose my current data, or will it auto migrate saving my data? Then I guess I'd have to add drive 8 to actually increase total storage space.
Another question: All my drives are currently 12 TB. When purchasing new drives is it OK to add a 16 TB drive? I assume the RAID array would only use 12 TB. But down the line it might be nice to gradually purchase larger drives for future arrays.
Marc_V
Mar 24, 2020NETGEAR Employee Retired
If you are in RAID5 on your 6 disk XRAID configuration then yes it will change to RAID6 once the 7th drive is added. No data loss the array will sync automatically but you are right that you need to add the 8th drive in order to have an increase to the capacity.
It is fine to add a larger capacity drive, you will then have to replace 2 more drives to the same capacity you added in order for the unused capacity to be added if you have added a larger capacity drive.
HTH
Regards
- StephenBMar 25, 2020Guru - Experienced User
Personally I'm keeping two empty slots in my RN526x. That gives me the option of adding two SSDs - either for ReadyTier or as an independent volume for data where I want higher-performance access.
As far as RAID-6 goes, I do think that is reasonable especially if you have 7-8 drives in the array. Restoring a massive volume takes a while - especially if your backup NAS is in a remote location. RAID-6 reduces the odds of volume loss (though of course it also doubles the RAID overhead).
I am using RAID-5 myself, but my backup NAS is on-site, and I can immediately switch to it if the main NAS fails.
