johnwehardy
May 20, 2017Aspirant
What is the maximum HDD size for my ReadyNAS 2120 v2
What is the maximum HDD size for this device. I have 4TB western Digital Disks and want to upgrade
Sandshark
May 20, 2017Sensei
RN2120 ro RND2120?
Unfortunately, Netgear made some poor choices in badging their NASes, and what is labeled an "RND2010 V2" on the lable is probably not what is considered a "V2" product today. If you unit runs V4.1.x firmware, then it is what is considered a V1 (Gen 1 would be a better name) and the max it can handle is 2TB drives. It if is a true V2 (and I don't think there was an RND2120 of that generation) and runs V5.x firmware, it will handle larger drives. The gen 1 product will also be a -100NAS model where the gen 2 is a -200NAS.
On the other hand if it is an RN2120 (4-drive rack-mount), it's a current model and can also handle larger drives.
johnwehardy
Hi Sandshark,
thanks for the response.
Checking the Netgear serial number function, my unit is a RN2120v2 (serial no: 3SJ344ER002A8).
I'm using Firmware version 6.6.1.
i currently have 4 x Western Digital 4TB HDD : WD40EZRX-00SPEB0 and need to upgrade.
After visiting
https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
I bought 4 x Seagate SkyHawk ST10000VX0004 10tb Disks, howver thay would not power up, the connectors must be in slightly different places.
the website says 'This disk should be compatible based on the test result of another disk in the same series from the disk manufacturer.', but at almost £440 a pop i can't take a 'suck it and see' approach again.
Hence asking the community for suggestions / recomendations.
Anything you can do to help will be welcome.
Best Regards
John
- cpu8088May 20, 2017Virtuoso
seagate skyhawk is for serveillance optimised for write not read
why not get the wd gold?
- mdgm-ntgrMay 20, 2017NETGEAR Employee Retired
With 10TB disks you'd probably need to remove the toolless insert and screw the disks into the tray using the drive tray screws that came with the NAS.
- JBDragon1May 21, 2017Virtuoso
I just don't get when they do dumb things like changing the screw pattern on the drives. Why? Make things a challage for people? Don't want to stick witht he standard?
