aaseef021
Jan 07, 2020Aspirant
What port is ReadyNAS configured for, can I change it
What is the default port for ReadyNAS 516, can I change the port if so what is the range?
- Jan 07, 2020
aaseef021 wrote:
I mean by when you access it via IE or chrome. IP / port?
It uses the normal HTTP/HTTPS ports of 80 and 443.
You'll see a way to set up a second HTTPS port in system->settings->services->HTTP. If you can to use that second port then you need to include it in the browser URL.
I am wondering why you are asking.
aaseef021
Jan 07, 2020Guru - Experienced User
