nrobinson1
Jun 10, 2015Aspirant
What to replace ReadyNAS NV+ v1 with
Hi All, So my NV+ v1 just had the PSU go boom... when I searched on the forums it seems there is a work around by re-wiring anATC Power Supply, but not sure I'm up for this, and it is an opportunit...
nrobinson1
Jun 12, 2015Aspirant
So actually a replacement power supply at £70 is probably the best option to get the old NV+ up and ruinning to get the data off and then look at a replacement?
My problem is always effectively backing up >3TB data... and as it is all movies, my feeling was that I can always re-rip and files I lost, but don't fancy doing the whole lot!
Cheers,
Nik.
Cheers,
Nik.
