nrobinson1
Jun 10, 2015Aspirant
What to replace ReadyNAS NV+ v1 with
Hi All, So my NV+ v1 just had the PSU go boom... when I searched on the forums it seems there is a work around by re-wiring anATC Power Supply, but not sure I'm up for this, and it is an opportunit...
vandermerwe
Jun 12, 2015Master
No.
The best option is what mdgm has described.
The process involves using the new nas to retrieve the data, it's just that you will need somewhere to back it up to, which hopefully you are going to do long term.
The only advantage of getting a psu is that you will be able to use the nv+ as a backup device for the new nas; that's assuming of course it works normally with a new psu.
