nrobinson1
Jun 10, 2015Aspirant
What to replace ReadyNAS NV+ v1 with
Hi All, So my NV+ v1 just had the PSU go boom... when I searched on the forums it seems there is a work around by re-wiring anATC Power Supply, but not sure I'm up for this, and it is an opportunit...
mdgm-ntgr
Jun 18, 2015NETGEAR Employee Retired
Well you could go with the RN104 or the RN204 if you want.
You cannot use a NV+ v2 to recover data from a NV+ v1. To tell the difference between the two see http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
