nrobinson1
Jun 10, 2015Aspirant
What to replace ReadyNAS NV+ v1 with
Hi All, So my NV+ v1 just had the PSU go boom... when I searched on the forums it seems there is a work around by re-wiring anATC Power Supply, but not sure I'm up for this, and it is an opportunit...
mdgm-ntgr
Jun 18, 2015NETGEAR Employee Retired
nrobinson wrote:
I was using X-Raid.
Then you can get either the 104 or 204 if you wish.
If you do get a new ReadyNAS it is important not to insert the disks into the NAS until prompted to by support.
