ruoverrated2
Jul 14, 2015Aspirant
where to get new PSU for Readynas 4200 / how to disable beep
Hi, one of the psu of my readynas 4200 died yesterday. I have two questions: 1. Where can I order a new psu? 2. Are there alternatives, for example a psu which make less noise? Or would it be...
ruoverrated2
Jul 16, 2015Aspirant
Ixa wrote: Try to contact Netgear Support and check if its possible for you to get a replacement PSU: http://support.netgear.com/general/contact/#tab-call
As far as I know, beeping would also occur if only one of the two PSU is connected to power. (Someone correct me if ever I'm wrong :D )
Hi, thanks. It is correct that beeping also occurs if only one psu is connected.
The issue is that I currently only have one working psu, so it will continously beep. (and the beep is very loud). I don't know how the beep is generated. Is there something I can change in raidiator or on the motherboard to stop it from beeping?
wlahood
Jul 19, 2017Aspirant
Hi Henri,
I have the same problem with an unpowered psu. Can you tell me if you solved the beep problem?
- SandsharkJul 21, 2017Sensei
The chassis for the 4200 is a standard SuperMicro one and power supplies (Ablecom PWS-702A-1R on my 4200V2) are avalable lots of places. I bought a used pair for $20 plus shipping on eBay. Note that while other wattages are available, SuperMicro does not recommend mixing them.
As for shutting off the beep, it's supposed to turn off if you pull out the unused/broken supply. I've not tried it, though.
