ruoverrated2
Jul 14, 2015Aspirant
where to get new PSU for Readynas 4200 / how to disable beep
Hi, one of the psu of my readynas 4200 died yesterday. I have two questions: 1. Where can I order a new psu? 2. Are there alternatives, for example a psu which make less noise? Or would it be...
RX
Jul 14, 2015Luminary
Try to contact Netgear Support and check if its possible for you to get a replacement PSU: http://support.netgear.com/general/contact/#tab-call
As far as I know, beeping would also occur if only one of the two PSU is connected to power. (Someone correct me if ever I'm wrong :D )
