ruoverrated2
Jul 14, 2015Aspirant
where to get new PSU for Readynas 4200 / how to disable beep
Hi, one of the psu of my readynas 4200 died yesterday. I have two questions: 1. Where can I order a new psu? 2. Are there alternatives, for example a psu which make less noise? Or would it be...
itsjasper
Jul 14, 2015Luminary
JennC1 wrote: This NAS has external PSU which I believe the part number is 331-10050-01, it is best you contact support to check the HW warranty of your NAS and the appropriate part number for the PSU. If the PSU is for replacement, they process replacement for the PSU.
You also have an option of redundant PS, model number is RPSU02-10000S
You mean removable PSU, there are no external PSUs on the rackmount product line. They are hot-swappable.
http://www.downloads.netgear.com/files/ ... June11.pdf
