KillerBob
Mar 31, 2012Aspirant
Which 3TB HD for Pro Pioneer
Hi, I am still pondering if/when to upgrade the 6 HDs in my Pro Pioneer, and I checked out the HCL, and there are only a handful of approved 3TB HDs. Hitachi Deskstar 7K3000 HDS723030ALA640 Hi...
PapaBear1
Apr 04, 2012Apprentice
Can't speak directly to the Pro BE/Pioneer/6, but I have two of the Hitachi HDS5C3030ALA630 in use in two NVX units since last June and they have performed well for me. I was expanding from 4 x Seagate ST1000528AS drives in each unit resulting in a mix of two 5400RPM and two 7200RPM drives. I was planning to replace all 8 of the drives, but the price spike hit before I did so and decided to wait. They have come down some but since I am only at 48% of my available volume, I will wait a bit more.
