Jun 26, 2012Aspirant
Which NAS actually suits my needs?
I have been looking through the ReadyNAS range and as far as I can tell not a single product meets my specific needs :? I want a four bay unit, based on an Intel chip (so that I have full Plex supp...
Jun 27, 2012Guru - Experienced User
You can also connect the USB 3.0 drive to your PC and copy the data over your LAN network. If you have a gigabit network, you likely will get faster copying that way (esp. if your drive is using a PC format, and not ext3/4).
1234568 wrote: I often need to take large amounts of data off-site. I know that i can download it via remote access, but many places in the UK impose download limits. This is where an external hard drive comes in handy.
As i am copying lots of data USB 2.0 is frustrating...
