networkn
Dec 06, 2011Aspirant
Which NAS for Upgrade of DUO
Hi There! I have had my DUO 2 years and I hate it with a passion. It's SO slow and every unexpected shutdown requires a rebuild which takes 24 hours (during which time it's unusable). I would li...
mdgm-ntgr
Dec 06, 2011NETGEAR Employee Retired
If using wireless, that will be the bottleneck. See ReadyNAS Performance Expectations
For an ethernet wired connection you can expect 2-3x the speed of the Duo.
See The Performance Section of The Definitive Guide to the ReadyNAS Ultra Series
Also take a look at The Performance Section of The Definitive Guide to the ReadyNAS Duo
Real world speeds will be a bit slower, but it does depend heavily on what files you are using. For large files speeds should approach what's shown in the Definitive Guides. For lots of small files speeds will be slower.
