dmahon1
Jun 25, 2015Aspirant
Which NAS
I have a ReadyNAS NVX with 4 disks. As one of my backup disks is now too small, I can either get a bigger one or take the opportunity to buy a new product, then usethe NVX as a backup (with ReadyNAS R...
Jun 25, 2015Guru - Experienced User
The RN104 and RN204 would also serve your needs, though I think the RN104 might a bit slower than your NVX.
Migrating with rsync works, just make sure to match the UIDs and GIDs of any user accounts. Personally I just always use the admin account, which already matches across the platforms.
