dmahon1
Jun 25, 2015Aspirant
Which NAS
I have a ReadyNAS NVX with 4 disks. As one of my backup disks is now too small, I can either get a bigger one or take the opportunity to buy a new product, then usethe NVX as a backup (with ReadyNAS R...
RX
Jun 25, 2015Luminary
dmahon wrote: That will recreate the shares, including user shares, on the new NAS and can put them in the main drive (C:), not in a backup share (eg Pablo) like the example in the link?
It will not recreate the shares on the destination NAS (RN314), you will be the one to create the share on the destination NAS then you will select which share (on the destination NAS) where you will backup the files from your NVX. If you want to select the default backup share on the destination NAS, then its alright as well.
