dmahon1
Jun 25, 2015Aspirant
Which NAS
I have a ReadyNAS NVX with 4 disks. As one of my backup disks is now too small, I can either get a bigger one or take the opportunity to buy a new product, then usethe NVX as a backup (with ReadyNAS R...
Jun 25, 2015Guru - Experienced User
What I do is re-create my shares on the new NAS, and then create an rsync job for each on the new NAS. They will end up in the the correct shares.
dmahon wrote: That will recreate the shares, including user shares, on the new NAS and can put them in the main drive (C:), not in a backup share (eg Pablo) like the example in the link?
I also use frontview backup for backing up those shares (same concept in the reverse direction), though you can use replicate as well.
Do you use the "private" home shares?
