jonnymorris
Mar 17, 2015Aspirant
Which ReadyNAS for business backup?
Hi, We currently have a home-made backup solution entailing several large old Dell 220S units connected to servers, running scripts to copy changed files from all three of our offices across the in...
Mar 25, 2015Guru - Experienced User
You could have stopped the sync, switch to flexraid and re-create the volumes you wanted. That would have saved you some time.
