rejoyce1
Jul 23, 2012Aspirant
which UPS to buy?
Hi
I have a ReadyNAS Duo with 2 x 2TB Seagate barracudas. I am interested in adding UPS as I've had a few outages for various reasons, I am just looking for a low cost option that will add another layer of protection, I will most likey only run the ReadyNAS + maybe a DSL modem and router, nothing massive. Can anyone help with a suggestion, I have been looking at various APC devices for a few days and just can't come to a decision, I think I'd like something with user replaceable batteries, as this seems a bit of a no brainer
thanks
Richard
PS: Sorry if this question has been asked before, I am just looking for a bit of advice, :o
thanks
Richard
- rejoyce1AspirantHi
just to share my experiences, I bought the APC Power-Saving Back-UPS 550, 230V (BE550G-UK), it cost £66, about $100. I plugged it in and in seconds it was working, looking good so far, I think I am just going to cut the power and see what happens, after all that's what I'm trying to protect against!
thanks for the help
Richard :D - PapaBear1ApprenticeIf you have not already done the trial, StephenB came up with a good test. Shut down the NAS normally and plug it directly into the mains and then restart. With the UPS cable connected to the NAS is should detect the UPS. Pull the plug on the UPS and when it gets low, it should shut down the NAS normally. If it does not, there is no sudden shut down of the NAS since it is on a separate power source.
If it works, you can then plug the NAS back into the UPS and plug the UPS back into the mains. After the UPS has built up a bit, you then then restart the NAS. - HERBIEOAspirant
rejoyce wrote: Hi
thanks for the help
Richard :D
Did you just buy this ? it's a shame you did not see my post here http://www.readynas.com/forum/viewtopic.php?f=24&t=65438#p363549 - dsm1212Apprentice
claykin wrote:
Get yourself some of these.
http://www.amazon.com/C2G-Cables-03137- ... +liberator
Cool, there will be a couple in my next amazon order. Should have thought of that. Thanks! - PapaBear1ApprenticeActually a few years back while browsing in the electronics department of Wal-Mart, I found a couple at a good price. If you are in a Wal-Mart or other store before you order, check out the electronics section.
