max2012
Nov 30, 2012Aspirant
Why can't I use 2TB in my ReadyNAS Duo?
I tried to expand my NAS box disk capacity, the model number printed on box showed ReadyNAS Duo RND2110 V2. I thought it was a ReadyNAS Duo V2 so I purchased 2 3TB disks (Seagate ST3000DM001) accordin...
mdgm-ntgr
Nov 30, 2012NETGEAR Employee Retired
Your disks are using GPT partitioning. You need to reformat them using MBR partitioning or wipe the partition table off the disks.
