max2012
Nov 30, 2012Aspirant
Why can't I use 2TB in my ReadyNAS Duo?
I tried to expand my NAS box disk capacity, the model number printed on box showed ReadyNAS Duo RND2110 V2. I thought it was a ReadyNAS Duo V2 so I purchased 2 3TB disks (Seagate ST3000DM001) accordin...
max2012
Thanks, but this didn't seem to work. here is what i did, I attached an USB adapter to the disk, reformat it in win7 using MBR partitioning(instead of GPT, now I can only have 1 primary partition of 2TB with NTFS). re-insert the disk, it would show a "corrupt root" error so I did a factory reset (holding reset for 30 secs while powering up).
but after all this, it still show up 742 GB allocated, any idea? I also tried wiping out the partition table (w/o reformatting).
