max2012
Nov 30, 2012Aspirant
Why can't I use 2TB in my ReadyNAS Duo?
I tried to expand my NAS box disk capacity, the model number printed on box showed ReadyNAS Duo RND2110 V2. I thought it was a ReadyNAS Duo V2 so I purchased 2 3TB disks (Seagate ST3000DM001) accordin...
Dec 01, 2012Guru - Experienced User
He does have 3 TB disks (ST3000DM001). I think he wants to try and partition them manually so the NAS will see a 2 TB drive.
mdgm wrote: I think I misread your post. 3TB disks aren't supported and will be only recognised as having 746GB of capacity. 2TB disks will work though.
