max2012
Nov 30, 2012Aspirant
Why can't I use 2TB in my ReadyNAS Duo?
I tried to expand my NAS box disk capacity, the model number printed on box showed ReadyNAS Duo RND2110 V2. I thought it was a ReadyNAS Duo V2 so I purchased 2 3TB disks (Seagate ST3000DM001) accordin...
Dec 07, 2012Guru - Experienced User
2 TB will work. I have two ST32000542AS in my duo V1.
I suggest avoiding the ST2000DM001 - at least search the forum before purchasing it. I'd go with the WDC WD20EFRX myself.
