mpjbay
Nov 05, 2011Aspirant
will 4TB drives be compatible with readynas nvx and if so wh
I am maxed out with 4 3TB drives and would like to know if 4TB drives will be compatible and if so when? This way I can compensate until larger drives are or are not accepted.
mpjbay
thx teknojnky :) it looks like 4tb is not supported with the nvx but hopefully that will change with the next fw upgrade.
