mpjbay
Nov 05, 2011Aspirant
will 4TB drives be compatible with readynas nvx and if so wh
I am maxed out with 4 3TB drives and would like to know if 4TB drives will be compatible and if so when? This way I can compensate until larger drives are or are not accepted.
sphardy1
Nov 06, 2011Apprentice
Drives are added to the compatibility list when tested. Drives are tested once available... You are not going to get any guarantees before testing is done, but there is currently no reason or any form of indication that 4TB or even larger drives cannot be supported
