mpjbay
Nov 05, 2011Aspirant
will 4TB drives be compatible with readynas nvx and if so wh
I am maxed out with 4 3TB drives and would like to know if 4TB drives will be compatible and if so when? This way I can compensate until larger drives are or are not accepted.
PapaBear1
Nov 07, 2011Apprentice
If and when they are released and you feel the urge to experiment on the bleeding edge of the new technology, I would recommend that you choose a model that is an expansion of an existing 3TB drive that is compatible. That will give you a better chance of success. But do keep in mind that with unsupported drives, tech support will not assist. Keep a good backup and it is never advised to use experimental drives or beta firmware on an NAS in operational use.
