devhen
Dec 09, 2013Aspirant
Will my Duo v2 support 2x4TB Seagate ST4000DM000 drives?
I'm wondering if my ReadyNAS Duo v2 will work with two 4TB Seagate ST4000DM000 hard drives and be able to utilize the full 4TBs. I don't care if this will void my warranty or if the ST4000DM000 is off...
devhen
Howdy mdgm! You helped me out a long while ago when I first got the Duo v2 and Frontview didn't have options for increasing the drive spin-down time. Thanks again for that!
So I'm running what my Duo v2 thinks is the latest firmware, 5.3.8. Apparently 5.3.9 has been released but when I do an update the Duo v2 tells me I'm using the latest firmware. I should be able to manually update it to 5.3.9 if necessary.
