devhen
Dec 09, 2013Aspirant
Will my Duo v2 support 2x4TB Seagate ST4000DM000 drives?
I'm wondering if my ReadyNAS Duo v2 will work with two 4TB Seagate ST4000DM000 hard drives and be able to utilize the full 4TBs. I don't care if this will void my warranty or if the ST4000DM000 is off...
mdgm-ntgr
Dec 09, 2013NETGEAR Employee Retired
You should be able to use 4TB disks. Some users have run into issues though when the volume gets very full of not being able to write.
