devhen
Dec 09, 2013Aspirant
Will my Duo v2 support 2x4TB Seagate ST4000DM000 drives?
I'm wondering if my ReadyNAS Duo v2 will work with two 4TB Seagate ST4000DM000 hard drives and be able to utilize the full 4TBs. I don't care if this will void my warranty or if the ST4000DM000 is off...
devhen
That's too bad, hopefully there will be a fix for that at some point. It probably won't be a problem for me, I usually upgrade before I get to 80%.
Thanks for your help. I'll be installing the 4tb drives this week, hopefully it goes smoothly. I think it will. Thanks again.
