GDA_LLC
Nov 07, 2016Aspirant
Writing images from a Cognex machine vision camera to a NAS RN31400
I am saving inspection images from two Cognex machine vision cameras to the NAS using the built in FTP server. I need to know the settings of the NAS that will allow the most images to be written to...
Nov 07, 2016Guru - Experienced User
GDA_LLC wrote:Images are 2Mb each, we are sending them once very 250ms, so 2Mb x 2 cameras x 4 times per second = 16Mb/sec, not anywhere near 100Mb/second!?!?
Are you using megabytes or megabits here? Are you running fast ethernet or gigabit on the network path?
- GDA_LLCNov 07, 2016Aspirant
the Cognex cameras only have 100Mb ethernet to the switch. From the switch to the NAS I have one GB Ethernet connection. The NAS has two ports so I wasn considering setting up the IP address of the second port and having each camera write to one of the ports. Image are in Megabytes.
Greg
- StephenBNov 07, 2016Guru - Experienced User
It's not completely clear to me where the bottleneck is.
You could
(a) retarget the cameras to point to a PC running an FTP server (perhaps FileZilla) and see if that performs differently
(b) aim two FTP clients at the NAS from PCs, and attempt simultaneous uploads of a group of 2 megabyte files, and measure the NAS FTP server throughput.
Those two tests should help sort out where the problem lies.
