QuackingPlums
Oct 05, 2011Aspirant
X-RAID upgrading from 2 drives to 4
If I had an NV+ with two drives (400GB each) in X-RAID configuration and I wanted to replace them with say, 4x1TB units, are my calculations below correct for each step in the process?: At start, 2...
TeknoJnky
Oct 05, 2011Hero
since you only have 400 gig or so of data, it would probably be faster to back it up (to a pc or external drive, using one of your new drives if necessary) then factory default with the remaining new disks.
btw 4x 2tb drives gives 5555gb, see my sig.
