QuackingPlums
Oct 05, 2011Aspirant
X-RAID upgrading from 2 drives to 4
If I had an NV+ with two drives (400GB each) in X-RAID configuration and I wanted to replace them with say, 4x1TB units, are my calculations below correct for each step in the process?: At start, 2...
mdgm-ntgr
Oct 06, 2011NETGEAR Employee Retired
TeknoJnky wrote: since you only have 400 gig or so of data, it would probably be faster to back it up (to a pc or external drive, using one of your new drives if necessary) then factory default with the remaining new disks.
+1. Of course you should upgrade to the latest RAIDiator before doing a factory reset so you can get a clean setup on the latest firmware.
