QuackingPlums
Oct 05, 2011Aspirant
X-RAID upgrading from 2 drives to 4
If I had an NV+ with two drives (400GB each) in X-RAID configuration and I wanted to replace them with say, 4x1TB units, are my calculations below correct for each step in the process?: At start, 2...
QuackingPlums
Oct 06, 2011Aspirant
PapaBear wrote: There is only one Samsung 1TB on the Hardware Compatibility List (HCL) and it is the F1 HD103UJ.
Really?! I'm looking at the HCL right now and it says the 2TB F4 HD204UI is on it - am I looking at the wrong list?
http://www.readynas.com/?page_id=82
TeknoJnky wrote: since you only have 400 gig or so of data, it would probably be faster to back it up (to a pc or external drive, using one of your new drives if necessary) then factory default with the remaining new disks.
btw 4x 2tb drives gives 5555gb, see my sig.
Good point. I wasn't going to buy all four disks at the same time from the same place (to avoid having them from the same batch, if there's a potential for bad batches - does anybody still do this?) so I was thinking two, then another two 3-6 months down the line.
I have to update RAIDiator anyway, since I'm only on 4.1.4 and this doesn't support 4K sectors does it?
