QuackingPlums
Oct 05, 2011Aspirant
X-RAID upgrading from 2 drives to 4
If I had an NV+ with two drives (400GB each) in X-RAID configuration and I wanted to replace them with say, 4x1TB units, are my calculations below correct for each step in the process?: At start, 2...
QuackingPlums
Oct 06, 2011Aspirant
By "migrate" you just mean that I can't simply move them from one device to another and expect all my shares to be intact, right? There's nothing physically changed on the disks that prevents me from just wiping them and starting afresh with 4 clean 2TB drives in a new ReadyNAS Ultra or Pro, right?
I guess if I'm ready to upgrade to 3TB disks then I may as well just leave the NV+ as it is and buy myself a new Ultra (or whatever) and a new set of disks to go with it!
