Avram
Nov 17, 2017Aspirant
X-Raid vertical expansion - harddrive compatibility
We run a ReadyNAS 4200 - RN12T1210 (RAIDiator-x86-4.2.31) with 12 of 1TB harddrives drives and we want to proceed with a vertical expansion. Unfortunately the harddrive compatiblility list is listin...
- Nov 20, 2017
Avram wrote:
You are saying that I won’t be able to get more than 16 TB per volume. Can I assume that it is not worth it to replace all 1TB 12 harddrives with 2 TB since the system will not recognize more than 16 TB?
You could do a factory reset with 12x2TB in place. That will work, and give you the full volume (22 TB with RAID-5, 20 TB with RAID-6). You won't be able to expand that volume, and since it requires a factory reset, you would need to restore all the data from a backup.
Avram wrote:
However, if I can get an extra 7 TB to the existing 9 TB that will be ok for a few more years and the next upgrade will be the unit itself.
That is not guaranteed, it depends on the initial size of your volume. For instance, if you started with 1 TB and then added the remaining disks, then you'd already be at the growth limit of your volume. You'd have to look through the expansion history to figure out where your ceiling is.
meshedlibrarian
Our ReadyNAS 4220 has run Seagate ST33000650NS for years with no issues.
https://www.newegg.com/Product/Product.aspx?Item=N82E16822148747
~meshed
Avram
Thanks meshed but yours is a more advanced unit and I don't think 4200 is accepting harddrives larger than 2TB (at least not acordingly with compatibility list).
Avram
