Rachakondaashok
Feb 16, 2018Aspirant
XRaid 5 will support for 8 harddisk (RR331200)
Hi Team, I have query that for RR33XX device i am going to insert 8- 6TB harddisks and i have a quesry that shall i can configure x Raid with Raid 5 configuration? Regards, Racha..........
ukmagic
Mar 18, 2018Aspirant
I'd like to point out though that with RAID5 and disks of that size, you are putting an awful lot of faith in there not being another disk die during a RAID rebuild, You'd be better leaving it as RAID6.
- StephenBMar 19, 2018Guru - Experienced User
In my view "better off" depends in part on the consequences of a failed array. RAID-6 results in both a performance hit for writes and of course the extra cost/storage penalty for dual redundancy.
For instance, if you have a highly-available backup NAS (or if the NAS itself is a backup), then RAID-5 might be enough.
That said, RAID-6 is reasonable, especially if the OP is planning to expand to use all 12 bays in the future. FWIW, RAID-50 is also reasonable (perhaps using 3 RAID-5 groups of four disks each).
