paulies
May 28, 2023Aspirant
Xraid readynas 214
Hi Just a quick question I’m rubbing xraid with my nas I like the idea of all the drives combined but if my readynas stopped working how easy it it to get the data off the disks? Is it just a matte...
- May 28, 2023
paulies wrote:
Is it just a matter of putting them in another Linux machine and I can recover it??The array can be mounted on an x86 linux system. You do need to know how to assemble and mount the array. OS-6 systems use mdadm (software RAID) and the BTRFS file system.
Of course if the file system gets corrupted as a result of the failure, then recovery could be more difficult - requiring you to purchase RAID recovery software.
paulies wrote:
but if my readynas stopped workingThe best way to keep your data safe is to implement a backup plan. RAID isn't enough.
May 28, 2023Guru - Experienced User
paulies
May 29, 2023Aspirant
Thank you for the reply, I know raid is not enough but the data I have if lost I could live with its just a pain getting it back but if its matter of connecting it to another system and been able to drag the file off files off that would be good 🙂
