Trumpy
Jul 21, 2009Follower
4.1.6 causing problems with Bittorrent Download Manager Duo
Since firmware upgrade I cannot access download manager page. I can get a work around by turning off, then back on the bittorrent service and this gives between a few seconds and about 2 mins access ...
dbott67
Jul 06, 2010Guide
A few other questions:
1. What version of Windows are you using?
2. What IP address does RAIDar report?
3. Are you typing the command in a command prompt window (as opposed to typing it in the RUN dialog box or creating a batch file)?
It should look like this:
