Trumpy
Jul 21, 2009Follower
4.1.6 causing problems with Bittorrent Download Manager Duo
Since firmware upgrade I cannot access download manager page. I can get a work around by turning off, then back on the bittorrent service and this gives between a few seconds and about 2 mins access ...
cjboonie
May 04, 2011Aspirant
Thanks UKZappa - your advice works a treat. It was really frutrating to lose the bittorrent control page. i'm glad there is a work-around.
ukzappa wrote: This may or may not be related to the problems outlined here but I sometimes cannot get access to the BitTorrent Download Manager. My browser just sits there with a white/blank screen.
There is a small bug.
When you add a download, 2 files plus place holder(s) for the actual download (possibly in its/their own directory) are added to the .bittorrent directory. Note that I'm referring to the hidden directory .bittorrent not the visible directory BitTorrent.
Use: net use <drive letter>: \\<IP address>\d admin /user:admin
to access .bittorrent.
When the download completes, it is moved to the BitTorrent directory. The remaining 2 files (?.fastresume and ?.torrent) are deleted. However, sometimes the delete is not performed. If this happens, you can no longer access the manager.
If you only had one torrent downloading then simply delete the contents of .bittorrent. If you have multiple downloads on the go, you will need to identify the correct 2 files. Simply look inside each .torrent file until you identify the correct one then delete it together with it's corresponding .fastresume file.
You will then need to stop and restart the BitTorrent service using Frontview.
You should now find all is well and you have access to the BitTorrent Download Manager as normal.
