flattened
Sep 30, 2016Apprentice
Access iSCSI LUN via O/S SSH RN102
Hi,
I have access the NAS via SFTP & SCP.
Where in the file structure is the actual LUN file so that I can copy it off the NAS for mounting elsewhere.
We have a iSCSI partition that will on...
- Sep 30, 2016
It is in a hidden directory .iscsi
mdgm-ntgr
Sep 30, 2016NETGEAR Employee Retired
Let us know whether you are able to recover your data from your LUN or not.
iSCSI is probably the most fragile way to store data on any NAS.
flattened
Oct 10, 2016Apprentice
Apologies for the late reply on this now.
Thanks for your help. After copying the 800GB of data to a PC (took 24 hours using SCP) I was able to mount the iSCSI using OSFMount, make an Acronis TIB of it, restore the TIB to a PC harddrive to ensure it was all there then factory reset the NAS, updated the firmware and robocopied the entire structure back over to the unit. No more iSCSI.
