pelopones
Feb 23, 2012Aspirant
AIRVideo is out of order
I installed your add-on AIR Video in my ReadyNas Ultra 4 ver. 4.2.19. I have quite big problem, because now I can not switch on any movies in my iPhone or iPad, because the client of AIR Video is announceing, that folder of MEDIA is empty . This problem is in both of my devices. On the other hand, certainly all movieas are in the folder MEDIA ( like avi.), because i can switch them help to uPnp. Do you know solution of this problem ?
- mdgm-ntgrNETGEAR Employee RetiredTry renaming the "media" share e.g. to "media1" (don't forget to click Apply) then rename it back again.
- peloponesAspirantYour advice is solving problem, when the contain of folder MEDIA is invisible in Windows via SAMBA. I know this solution. My problem is another. I have problem, that I will find in IPHONE Airvideo server which is running in Netgear – i will connect to the server, but when I look to the streeming folder, so I see 0 movies.
- peloponesAspirantI please you, Do you know solution of my problem with AirVideo? Anybody
