moonshadow
Nov 11, 2014Aspirant
apt-get -- Couldn't find package screen
Hello, I want to automate scripts for my Newznab installation on my ReadyNAS Ultra6 Plus using the screen command, but it is not available by default, and the apt-get command returns the error "Cou...
mdgm-ntgr
Nov 11, 2014NETGEAR Employee Retired
What happens if you use vi to uncomment (remove the # from the start of the line) the last line in /etc/apt/sources.list then rerun the apt-get commands mentioned above?
