moonshadow
Nov 11, 2014Aspirant
apt-get -- Couldn't find package screen
Hello, I want to automate scripts for my Newznab installation on my ReadyNAS Ultra6 Plus using the screen command, but it is not available by default, and the apt-get command returns the error "Cou...
moonshadow
Re-ran apt-get:
Then ran 'apt-get -f install' with no packages:
nas-EB-01-0D:/etc/apt# apt-get update
Hit http://www.readynas.com 4.2.27/ Release.gpg
Ign http://www.readynas.com 4.2.27/ Translation-en_US
Get:1 http://archive.debian.org etch Release.gpg [1033B]
Ign http://archive.debian.org etch/main Translation-en_US
Get:2 http://archive.debian.org etch Release [67.8kB]
Ign http://www.readynas.com 4.2.27/ Packages/DiffIndex
Hit http://www.readynas.com 4.2.27/ Packages
Get:3 http://archive.debian.org etch/main Packages [4218kB]
Fetched 4287kB in 4s (914kB/s)
Reading package lists... Done
nas-EB-01-0D:/etc/apt# apt-get install screen
Building dependency tree... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
libapache-mod-php5: Depends: php5-common (= 5.2.0-8+etch13) but 5.4.30-0rnx1 is to be installed
php5-mcrypt: Depends: php5-common (= 5.2.0-8+etch13) but 5.4.30-0rnx1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
nas-EB-01-0D:/etc/apt# apt-get -f install
Correcting dependencies... Done
The following packages will be REMOVED:
libapache-mod-php5 php5-mcrypt
0 upgraded, 0 newly installed, 2 to remove and 37 not upgraded.
2 not fully installed or removed.
After this operation, 5439kB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database ... 18547 files and directories currently installed.)
Removing php5-mcrypt ...
Removing libapache-mod-php5 ...
Processing triggers for libapache2-mod-php5 ...
Your apache2 configuration is broken, so we're not restarting it for you.
Setting up php5-zendopcache (7.0.3-0rnx2) ...
ERROR: /etc/php5/mods-available/zendopcache.ini does not exist
dpkg: error processing php5-zendopcache (--configure):
subprocess post-installation script returned error exit status 2
Errors were encountered while processing:
php5-zendopcache
E: Sub-process /usr/bin/dpkg returned an error code (1)
